Long story short, I am legally blind and use an electric wheelchair. I need lots of light to see, therefore rigged up 2 55 watt helogen lamps in series to run off of 24 volts and added a roll bar with 4 more 55 watt lamps in a series parallel configuration for same 24 volt operation. I had purchased some 25 and 35 watt lamps, but they were blown away by the 55 watt lamps.
Here are the first set of lamps http://www.wheelchairmodifications.org/light_upgrades_01.htm
Here is the roll bar http://www.wheelchairmodifications.org/roll_bar.htm
The 2 lamps work well for in dark areas in doors and on the street. Now when it comes to bullitin boards, chaulk boards and other areas I can not see well, man the roll bar brightens things up. I had considered using HID lamps, but the few kits I saw in catalogs they seem to draw just as much power as regular lamps, plus i had to mount a highpower transformer to operate them and hate to have that by my head or near my body.
YOu guys are the experts here, has HID changed that much or do they make LED head lamps?
