Travis2020
- Joined
- Jan 17, 2020
- Messages
- 6
Hi, I'm working on a light project. If you guys can help me that will be great.
Project:
1. Using 7.4v or 11.1v battery 2200mah
2. Which led do you recommend I should use to obtain high lumen yet not dissipate too much heat or need a heat sink? If does, it'll just be the copper it sits on and small metal casing...
3. Should I regulate the current to reduce the heat?
4. Need something small and compact, one emitter.
5. What's the newest and latest led?
6. Is dome better than flat? I plan to place optics over it to concentrate the beam.
Thank you.
-Travis
Project:
Thank you.
-Travis
