ForrestChump
- Joined
- Oct 20, 2014
- Messages
- 3,097
No problem my good man! And I, in turn, promise to send back whichever one of your two new E1DL's you choose to send to me!
Dang it. Busted. :mecry:
LED's should only be made available in HCRI. All others are inferior. :thumbsup:
That sounds like my wife. That and, "Why would you spend $200 on one flashlight when I could buy 200 flashlights for the same price from the Dollar Store?" Of course she happily took my cool white HDS Rotary after I got my high CRI Rotary. She prefers cool white because she thinks it looks brighter, and she loves the simplicity of the Rotary interface.I'm thinking my wife's reaction might be something along the lines of, "That's nice - it's a flashlight and it lights up the dark ... just like your other flashlights".
Yep. High CRI lets you see what you've been missing. Literally. When I got my first high CRI light, an HDS Clicky, I was out in the garden doing a comparison between it and a cool white emitter. I turned on the cool white, looked at the even grayness with which plants were rendered, then I turned on the high CRI, and suddenly, I saw a brown rabbit sitting behind one of the plants. When I switched back to cool white, I noticed that the green leaves of the plants and the rabbit's brown fur had the same greyish tone making the rabbit virtually invisible behind the leaves. With high CRI, on the other hand, the colors "popped" making the rabbit clearly visible.I know I'm preaching to the choir here, but I'm just blown away by the color rendition when using this!
To answer your first question, it is what people want. A lot of people don't care about color rendering, they just want the brightest light they can get their hands on. I do wish there was more demand for high CRI, but since they usually have a lower output, the majority of consumers turn their nose up at them.I agree. I'm just SOOOO over the cold white, low CRI junk LEDs that all the manufacturers out there seem to think people want. I just don't think the few extra lumens are worth it (and it's not like low CRI variants on an LED double output). The REAL shame is that high CRI LEDs are so hard to come by in the first place. Even Cree makes a number of 85-90+ CRI variants of the XM-L2, with tints from warm to neutral white. But most of these are nowhere to be found (except for a few Armytek lights and P60 drop-ins). Zebralight actually seems to be one of the better manufacturers out there in terms of high CRI with their offerings that use the Philips Luxeon T emitters (which are quite good). But otherwise, good luck! Sometimes, a manufacturer might even have the light available with a high CRI emitter, but nobody wants to sell it. I guess that, as long as lumen count is all that's important to people, this will be the way things are.
BTW, is it just me, or do the lumens of a high CRI emitter just seem to be more 'effective' than the lumens of a low CRI emitter? In other words, does a high CRI emitter actually make better use of its available lumens? I would think that, if nothing else, a higher CRI emitter sould allow you to better see certain details that a lower CRI emitter might 'wash out' due to not being able to make out subtle color differences.
Sometimes, the cooler lights emphasize colors of interest more than a high CRI light would...so depending upon what you're looking FOR, the high CRI, or, the std CRI light might work best.
To give an example to illustrate the concept, we use certain wavelength lights to find things hidden from daylight/balanced light sources in forensic investigations. Blood or biologicals might pop out more distinctly for example.
The very fact that colors might be rendered differently can make some colors pop out where they would normally be more subtle, etc.
As for "the great unwashed" and their strong preference for whiter light - well, its their baseline. Its like those light bars you see on all the off road rigs now a days....massive lumen output, all in a pool right in front of the rig...glaring out any details for things off in the darkness. They perceive the massive lumens and the giant pool of brightness right in front of them as "BRIGHT!", and trying to convince them that they are now MORE likely to hit that deer they added lights to see in time....falls on deaf ears/blinded eyes.
:candle:
One day I hope to have my cake and eat it, too.
Yes, there are special-case situations where different colors are preferred, but for general, everyday use, I find warm high CRI to be the best because it makes things look the way I expect them to look.Sometimes, the cooler lights emphasize colors of interest more than a high CRI light would...so depending upon what you're looking FOR, the high CRI, or, the std CRI light might work best.
It depends on why they're backordered. Is it because they can't keep up with demand? Or is it because there's not enough demand to justify keeping them in stock as a regular item?I still disagree that people want higher output at the expense of lower CRI. Perhaps the best evidence to this is the fact that, at Illumination Supply, the neutral Zebralights tend to be on backorder while the cool Zebralights are mostly in stock.
It depends, but with a bright, tightly focused beam, your eyes will adapt to the bright hotspot which can make it harder to see areas that aren't illuminated.Thanks,- so cool White is more of a danger than good?.
turning on hcri like that wouldn't surely brighten up the area ahead as much.
i mean cool white is good to illuminate an area to see what's out there right?.
It will happen.
Years ago it was always "bright, small, long running...pick two". Well today you can have all three, with one of them in spades.
Having size and output/runtime to the point where you can be primarily concerned with things like UI and tint is a great thing.
As I am sure you are more than aware, given your join date.
I still disagree that people want higher output at the expense of lower CRI. Perhaps the best evidence to this is the fact that, at Illumination Supply, the neutral Zebralights tend to be on backorder while the cool Zebralights are mostly in stock. And speaking of Zebralight, the neutral XM-L2 lights can actually have really good color rendition these days. But the hit on lumens that they take compared to cool white is actually quite small - 930 lumens for a neutral SC62w (75 CRI) vs 1000 for a cool SC62 (65 CRI). So you don't have to give up alot of lumens for better tint/CRI.
I have a ~half dozen HCRI (mostly N219s) and as many NWs (mostly XMLs) but I use cool whites the majority of the time. I certainly like nice tints, and all else equal, HCRI > NW > CW, but I guess I'm just not a tint snob. If anything, I'm a sub-/low- lumen output and mode spacing snob, and in a few cases (OEM & Modded) dropping in the less efficient N219 in the same driver has reduced the usefulness the sub-lumen mode, which has spoiled the light for me. I even prioritize beam profile, UIs, build quality, and even pocket clips over the tint. But all that said, being a low lumen, night vision enthusiast, I suppose "color" at such low illumination levels is bordering on near black and white anyways .
