Der Wichtel
Yes I have the drivers in stock, just send me your order via email.
As for the LEDs I have some sources. I will mail them to you.
So you have the components on the driver completely covered with the arctic silver thermal epoxy?
Ok, I received my driver and heat sink today. One question though. How am I supposed to bond the driver to the heat sink so it will be cooled as well? There does not look like a good way to do this that would not involve just filling the cavity with thermal compound and shoving it in on top of it.
you should rather use thermal potting compound or thermal adhesive ( Arctic Silver Thermal Adhesive or Arctic Alumina Thermal Adhesive) than thermal compound/paste.
Hi,
this is how a buck converter converts the current/voltage:
http://en.wikipedia.org/wiki/Buck_converter
With "pulses" you mean PWM I think:
http://en.wikipedia.org/wiki/Pulse-width_modulation
However with PWM you can't regulate currrent, as it just turns the light on and off.
But you can use it in conjunction with a driver to dimm the brightness.
The adjustable version can control and regulate the current which is more efficient than PWM dimming. LED efficiency increases as well with current control compared to PWM.
Yes, sure you can replace the wires yourself. The wires are approx. 12xcm long as far as I know. The length depends on wire thickness.
You can use long wires but then you will waste a lot of power across them due to the resistance.
As for the SST-90 just send me an email.
last but not least just have a look over this thread. most of it has been discussed :thumbsup:
Re: H6Flex driving Luminus Devices SST90's « Reply #5 on: October 01, 2010, 01:45:16 PM » |
Sorry!!!!you got the wrong guy, you need DW for this...
