Der Wichtel
The minimum level is around 0.7A-1A
It is pure current regulation as I said before.
Ok, I think I have it repaired well. Since I will not be able to get this project together for a little while how can I test it to make sure it is working properly?
You can also use your multimeter and hook it up to the drivers output cables
No offense but I am trying to understand what the best is for the sst-90 when going into the lower modes: current or pwm with current combined.
LED efficiency increases as well with current control compared to PWM.
Via Paypal ordered: 1 x adjustable 9A, leads at ONE side (where the coil is located), international and registered mail, totally € 46,50 :wave:
Is this the best way to cool down the buck converter with cooling tape at the side of the microprocessor?
Leads as long as possible (12 cm).
SSR-90 white 5700K ordered at the adress you suggested! :thumbsup:
Input voltage will be 24V, I red that the mounted capacitors can handle 25V.
Now waiting till the funstuff arrives and looking for a nice floody/throwy reflector :lolsign:
Sure, I just don't know if the XML can handle the 5A.Will the 5 amp single mod driver fire up three XML?
Yes I got more than 5A with the XM-L as well during testing but the LEDs were mounted on a very large copper heatsink.
