Probedude
I bought some SSC P4 U-bin emitters from both KD and DX. The parts came in 'tape and reel'. I took one out, took a half dead 9V battery (since this is what was within arms reach) and proceeded to light up the emitter momentarily. Nice and bright and I didn't feel much heat from the package.
I then went off and showed the wife at the emitter size and how well it worked to flood the room with light. This time it was turned on a bit longer. Still the package was not above ambient.
Went back to my desk, tried to turn it on again and now it's dead.:sigh:
Took it to work, looked at it under a microscope
- bond wires look fine
- as much as I can make out, the die looks fine.
- I measure a diode drop in continuity from one terminal to the mounting base of the package but I get NO continuity from one terminal to the other, OR the other terminal to the base of the package.
ESD? I don't think it was heat. The 9V battery was pretty flat so it couldn't deliver the amps.
- from one terminal there are 3 bond wires. 2 go to the emitter die, one to a diode that is mounted on the substrate. What is that used for?
Any ideas what caused this LED to fail?
TIA,
Dave
Edit: Just looked at the datasheet and ESD spec is 20KV human body model.
So maybe it didn't die from ESD. I wasn't walking across the carpet, rubbing a balloon through my hair, etc. .. .
TIA,
Dave
