High powered Stinger
Aaron
MI
I saw a post recently that talked about upgrading the bulb and batteries of the SL Stinger. Does anyone exactly what battery pack and bulb to use that works? I have seen on E-Bay a battery pack that runs at 3600 Mah. Would this be effective with a WA or Ultra-Stinger bulb?
Thanks
I'm gonna use a custom 6v battery pack built by Wilkey that might I add is professionally level built. I'm gonna use a WA01111 or a WA01160 (un-potted, bare) that I got from the last WA group buy.
The Stinger reflector's hole will need to be drilled out a bit since these WA bulbs are bigger in diameter. Also, the light can no longer be used for long periods of time since it will generate excessive amounts of heat. As you know the Stinger in it's stock form gets hot after a while. Imagine it as a 6v scorcher! The lens will also need to be swapped out for glass or it will melt. I've melted some before in it's stock form by leaving it ON sitting face down on a table. /ubbthreads/images/graemlins/twakfl.gif
I've got B270 glass installed and have the 6V pack, just waiting for the WA bulbs to arrive. Can't wait. I'll post here when finished.
