High quality P60 type dropin that will handle 12 volts?
ebow86
Pennsylvania
Do anyone know of a high quality P60 type LED dropin that can handle 12 volts (4 CR123)? Most of the one's I see only handle 9 volts max.
Thrunite XP-G.R5
4v-13v multilevel drop in
〇 493 LED Lumens (1.5A Drive Current)
〇 3 Output Modes H>M>L - 100% > 40% > 1% = 493LED lumens > 200 lumens > 10lumens
〇 Memory mode: Remembers and activates to last level used.
〇 4-12V input voltage
〇 Cree XP-G R5 LED
〇 Outer spring is removable for some fitments
〇 Alumium textured/OP reflector with bronze heatsink base
〇 Bezel diameter: 26.5mm
〇 Copper base diameter: 19mm
〇 Height including support spring: 36.7mm
〇 Height excluding support spring: 28.8mm
http://www.thrunite.com/productsweb/3 Mode Drop-in.html
Just out of curiosity what are you using as a host?
Surefire 9P with A19 extender. I run a KT2 turbohead on it but I would like the ability to quickly switch to the normal 1.25 bezel with an LED dropin when I need it.
