Reviving this old thread! Its now Dec 2014. What do most people here recommend for a high capacity AAA rechargeable? Thanks.
Bumped. Feel free to ignore my post... just skip to the last line... (have battery fever).
I understand the advantages of LSD, in theory at the cost of absolute "max capacity" for the chem. After obsessive dredging for what is there and consuming the very generous Amazo-nLee (tE) reviews and others, I understand why the reviewers, in their infinite wisdom, direct everyone to "whatever teh cheapes eneloop-copy-best-deals are now." Can't go wrong recommending the best deal on the best battery for pretty much anything. These cells are, regardless of advertising if they are copies, 800 mah batteries (if AAA variety), that keep a decent bettery than 80%-charge over a long time and are good for
1500-3000 charges. There are 950mah pro varities good for 500 charges, old Sanyo XX, and newerish Panasonic Eneloop Pro. The Imedion (Powerex brand), afaict, currently holds the best LSD capacity rating, and its expensive, but (sometimes less than) half as expensive than actual Eneloop Pros, which it bests by at least 100mah in capacity, and likely total life charges (just a guess). EBL High Capacity batteries claim to be LSD, come precharged, but have been ferreted out as inferior LSD, though they do apparently have actually the highest capacity (no long term tests I can find, too new)... and relatively cheap. Tenergy Platinum are also decent LSD, higher capacity than Eneloop Pro, much less expensive, probably last longer. Duracell has (4thgen?) 800mah japanese duraloops available almost everywhere I go, and that's great, but they're 800mah and at the store more expensive than Imedions online, and by the looks of most of them, they've been there a while. SunLabz and FlePow are also, apparently, well-regarded lower cost LSD NiMH, with pretty and colorful labels.
LSD. Got it. Check.
But what else is there? I can't find these higher-capacity current generation non-LSD batteries, just the older lower capacity ones that the new LSDs beat handily.
The OP's example is a good test case, but for 2015 we should extend the hike just a bit beyond the distance the best quasi-LSD (EBL) out of a pack could get you, which is over the advertised 1100mah. Please don't recommend another light, shorter hike, longer legs, nor carrying the overly burdensome extra AAA cell.
So (by inductive reasoning, earlier... nm) I arrive at the possible existence of actual non-LSD NiMH AAA cells that push to the limits of the chemistry, accepting up to or beyond 1000 recharges but no promise nor expectation of any charge to speak of beyond a week or a few days, that blows past that 1100-1150mah by the difference between the non-negligible capacity limits of the freshly charged LSD and non-LSD cell varieties.
Please direct me to the non-LSD NiMH AAA 1200++ mAh (current generation) rechargeable cells. You have my gratitude.
