yaesumofo
So how do we rate flashlights?
Lux out the front right at one meter?
So that means we can use the emitter ratings in Lumens.
This makes things so simple.
The strength of the emitter is only important in the sense that we know how strong it can be.
The other parts of the equation like OPTIC or REFLECTOR.
Direct drive or regulated?
buck? boost? regulator efficiency?
Current to the emitter? Voltage?
All of those things come into play here. Many of us as Cpf's are interested in most of those specs right?
OK but in the end most people are interested in how bright is it?
Lets face it Horse power (or emitter lumens) does not directly relate to how bright the flashlight is.
It is one part of the picture.
What are your thoughts about how to consistently rate flashlights so that with a single number which gives us really good idea about what a flashlight will do?
Maybe we should come up with a formula something like this: ((Emitter lumens x lux (measured at one meter))*the voltage of the flashlight)) divided by (the width of the reflector or optic in mm X 1000)
Flashlights with more voltage and higher Lumen ratings will have a higher number.
Lights with weaker LED's or less voltage or smaller reflectors will have a smaller number as a result....
So how about it guys. Give it a try. Plug in the numbers for a few flashlights you have and lets compare results.
This formula will produce a number by which flashlights can be compared.
We can call the number something like FLUX.
OK OK call me crazy...
Yaesumofo
Yaesumofo
Yaesumofo
Yaesumofo
