Good news and bad news.
Bad news, the schottky diode (50V 2A rating) did not work. I also tried a 6A Power Supply Rectifying diode - no go either.
Good news, I collected some interesting data on the "evil" pulses.
I found the schottky diodes I though I had, but they were surface mount:
I soldered to short legs so that I could use them:
Here is data on a 1K resistor as the load - note this is pretty much picture perfect shape on all waveforms (this is at startup, before any push buttons):
Here are the ugly pulses on the small 5V bulb (this is at startup, before any push buttons):
Same but with the schottky diode - basically no difference:
Here I am using the 100 Ohm 100Watt power resistor set to about 6 Ohms (notice this has some inductance, but also, that it puts a bigger load on the PS than the 1K resistor):
I kept playing with the system and swaping bulbs, and I noted that as the duty cycle increases, and the Vrms increases, that the spikes become "smaller" in magnitude!
To capture these better, I am now triggering on the negative slow of the gate voltage.
Here is the 12 volt bulb - at startup:
Here is the 12 volt bulb - after one press:
Here is the 12 volt bulb - after twp press:
Here is the 12 volt bulb - after three press:
Here is the 12 volt bulb - after four press:
Here is the 12 volt bulb - after five press:
Here is the 12 volt bulb - after six press:
Here is the 12 volt bulb - after seven press:
Here is the 12 volt bulb - after eight press:
Here is the 12 volt bulb - after nine press:
Now I changed back to the smaller 5V bulb. Note that the spikes are much larger!
Here is the 5 volt bulb - after startup:
Here is the 5 volt bulb - after one press:
Here is the 5 volt bulb - after two press:
Here is the 5 volt bulb - after three press:
Here is the 5 volt bulb - after four press:
Here is the 5 volt bulb - after five press:
So it looks like the bulb's inductance plays a key role, but also the current draw on the battery.
I will keep testing over the weekend - I still don't understand why neither the schottky diode nor the regular diode seemed to help :confused:
Will
