Alan B
Back from vacation. Spent some time working on this, have some new designs. At this time the variation I like best is to drive a high side N channel 4.5V gate FET using a capacitor, resistor and diode from the PWM pin of the IC. Not sure this will work, need to do some calculations, but it appears to be sound. Anyone want to breadboard and test that? Apply a 5V square wave to the circuit and see if the FET stays cool??
The high side driver allows the voltage divider chain to be lower impedance since it is on the bulb side and not energized when the light is off. This is important to keep the off-current from draining the batteries. The lower impedance divider chain is required to get good accuracy from the on-chip ADC and still keep the parts count low.
Based on the small size of the C KIU socket I would propose that the first design be made for M*G D size. The design should be set up to work with the KIU socket without drilling a bunch of new holes in the KIU unit.
I received my KIU socket but have not found the instructions. I presume the Mag tower must be milled off and the KIU screwed to it. How is the assembly located in the M*G tube?
I have read pretty much the entire PIR1 thread. I can see a couple of common issues that need to be dealt with.
Calibration is one. I am considering calibration schemes that make it much easier for the end user to calibrate it without complicating the design.
-- Alan
-- Alan
