Hi there, i have just got 20 Cree Leds that came without being soldered to anything (bare Led). As i see the led has the power leads at both ends while at the middle is a square surface probably for heat dissipation (The LED looks like this --- I [_] I ). So here's the question ... Should i solder this surface (which is behind the led) to the board or is is just enough just to put heat dissipant silicon? Since soldering seems impossible under the LED
