How do I make a balanced battery pack?
poormanq45
I want to build a battery pack consisting of atleast 3 26500s in series. Maybe 3 more in parallel if it's possible to have them on one circuit.
I want to make this in to a pack and attach a charging pack. To do this safely it should be balanced, correct?
I understand the reason behind this. To make sure no individual cell is overcharged relative to the other cells.
How should I go about making a balance circuit? Google didn't give much information to circuit development.
I am using a hobby charger similar to the Turnigy that is recommended on this site.
Thank you for your help
Well i don't know much about this yet, but my logics tells me you must put a wire in between every joint of the cells (and in the front and in the back)... And wire it correctly to the balancing area. =) And then add the charging leads to fron and the back of the pack...
Anyways just my guess :D
