How much current to LED with 4x123 cells
jaybiz32
How much current would a q5 Led see if run with 4 123 primary li-ion cells direct drive?
Past a fraction of a second, none, because it would :poof: .
Also, Li-Ion is not primary, it's rechargeable. Ordinary lithiums are primaries.
What is the formula to figure out current to the led based on direct drive?
It also depends on the individual LED. In extreme cases(Using the Cree XR-E Q5 as an example), the Q5 will only be drawing 700 mA at 4v but a normal Q5 at 4v will be drawing well over 2 amp.
A driver also isn't that expensive.
