How to change Thrunite Catapult reflector?
CM2010
Any advice appreciated,ive unscrewed the head and the bezel and thats it.
Whats the next step?
Found the answer:
Dear zer0ne. Thanks very muche to support our products, I know it is not easy to replace, since we design with better waterproof. You can first twist the head from the LED modue. and then remove the bezel. and then push the bottom of the reflector. and then the lens will take out.and then take out the o ring and then, you can replace it. Thanks And Best Regards
David
