ChrisGarrett
I have the same charger, charge gen2/3 aaa eneloops at 500mah and have noticed from time to time that the bc700's readout says one (or more) has taken way over 800mah, like 895mah the last time I saw this. does that mean it's being overcharged?
they're all newish batts, 2013 date stamp, have run them down and recharged a number of times, etc. the recharge voltage was in the 1.5x range but took it out of the charger instead of waiting for "full" because I was afraid it was being damaged.
also given the battery is considered dead when voltage gets down around 1v, there must still be mah left in it at that point correct? so the battery 800 mah rating in effect means "800 mah above and beyond what's in it when considered 'dead'" so maybe seeing ~900 mah going into it isn't anything to worry about?
I was fiddling with some AccuPower 1200 AAAs in my BC-700 the other day, that are two years old and not doing so well. I.R. in the 1.80v range on my Maha C-9000 and some of them missed termination and seemed to keep charging for 20 extra minutes, before I terminated them.
I like my BC-700, but you need to watch it with batteries that might be 'hitting the wall.'
I remember early on, with some older batteries, I would miss a termination, here and there, but I was ignorant at the time and didn't put two and two together.
Chris
