How to compute runtimes for various LEDs/Batts
jcw122
Hi everyone,
I'm trying to figure out how to approximate runtimes for various LED and battery combinations. I'm having trouble figuring out what kind of runtimes to expect from various P60 drop-ins.
Example:
Cree XP-G @ 1.4 amps using a 18560....vs. same LED but a 17670
I don't know enough about electricity to figure this out, and I'm unsure where to look for the proper numbers for specific LEDs.
Thanks.
What are some of the accepted values for the different LEDs? I think XPG was 3.2?
This is only a rough estimate, but
Convert to watts, then calculate:
Guessing that your XP-G has a Vf of 3.2v (won't know until you measure), and you say the current is 1.4A (assuming that's at the tail). 3.2v x 1.4A = 4.48W
Now, say you're using an AW 2600mAh 18650. Calculate to WH 3.7v x 2.6Ah = 9.62WH, then divide battery capacity by emitter wattage: 9.62 / 4.48 = 2.15 hours. Reduce this by driver efficiency. Say (roughly) 85%: 2.15 x .85 = 1.83 hours or 1 hr. 50 min.
An AW 1500mAh 17670 would be: 3.7v x 1.5Ah = 5.5WH
5.5 / 4.48 = 1.23 hours. Reduce again: 1.23 x .85 = 1.05 or 1 hr
How do you account for batteries in series? Just add the mAh(1)+mAh(2), v(1)+v(2)?
V1+V2 is correct. The Voltage potential of 2xRCR123 cells in series is 8.4V.
However the mAh capacity of the series pair is equal to the mAh capacity of each cell. So a pair of RCR123 cells in series is 500mAh (for example).
