OneBigDay
I am hoping somebody can point me in the right direction on this.
I have a Cygolite Mitycross 350 bicycle headlight. It comes with a proprietary but standard "3.8v" enclosed waterproof battery pack. This battery pack plugs into the lamp portion of the light with what looks to me like a standard barrel type connector. The barrel is about 5mm wide, by exactly 15mm long. See photos below.
The reason for my post is that I have some 3.8v 26650 IMR cells (4000mAH) that I am using with some FM flashlight hosts, but it got me thinking I should be able to use these same cells as a backup or alternate power source for the Mitycross.
So 3 questions I guess for starters.
1) Any reasons why I should not try this or potential pitfalls
2) Is the above pictured barrel connector standard and if so where can I get one? I see some similar at batteryspace but they are only 8mm long.
3) Is there some kind of standard battery holders that are used for this type of application or am I looking at making a custom battery holder too if I go down this road?
