arek98
It could be heat-sinking. If star was used and was glued to heat-sink it could crack eventually from thermal stress (expanding, shrinking while heated, cooled).
Try unscrewing reflector and see if star is firmly attached, if you can easily pry it then it probably does not hold well anymore. You need to remove it anyway because it definitely looks cooked (all brown discoloration).
Get new star, solder it and try before mounting permanently.
I would also use thermal pad instead of thermal epoxy to mount it unless you can get one that stays flexible when cured (Arctic Alumina does not).
You could also use thermal paste and screws but there may be not enough space for screws under reflector and you would need drill and thread holes.
