How to fix WF-139?
sp5it
Poland
Hi. A firnd of mine gave me his 2 generation (4.95V open circiut) WF-139.
I dug through threads, but couldn't find solution except buying new charger :)
Did someone mod this charger to get proper charging voltage?
Can you point me to this solution?
Thank you, Mike
I believe the 2nd generation WF-139 with the OCV around 5v is the better of the various generations of the WF-139.
I don't think I have ever read of anyone fixing a WF-139, other than wiring up the side bays to charge 16340 cells.
Before jumping to conclusions, based solely on open circuit voltage, try charging a battery!
Check terminating voltage, no greater than 4.2v and cut-off, so there's no trickle charging.
If you fail either, chuck it and get something that works.
