If you are moderately handy with a soldering iron and want to save some money on an LED tower, I'd sign up on the feeler thread for a Netkidz tower kit for $25 plus shipping. I'd then get a 17mm diam KD1640 1000mA buck driver for $4. Scavenge for a suitable center spring (e.g., remove a spring from an unused remote control or child's toy) -- free. Order an XP-G R4 on an 8mm round MCPCB from nailbender -- $9 (you might have to buy 2 min, $18). Assemble your tower. Total price ~$46 (assuming you already have Teflon-jacketed 24 ga hookup wire and some Arctic Alumina thermal epoxy). At 1000mA drive current, the XP-G-R4 should deliver a calculated 325 emitter lumens while requiring only about 3.3W of power. I've measured the KD1640 driver at about 90% efficiency, so that means the driver needs only about 3.7W. If you use 3x16340 at a nominal 11.1V, that means only about 0.3A current draw at the tail or well over 1 hr of uniform output, cool-running run time. If you use 2x17500 at a nominal 7.4V, that gives about 0.5A draw and over 2 hr calculated run time. Realistically, I would expect even lower Vf at 1000mA, and thus longer run time. The datasheet spec for the XP-E, for example, is 3.4V at 700mA, while I've measured ~3.2V at 700mA for six different XP-Es.
