Problem resolved, sort of/ubbthreads/images/graemlins/icon3.gif
I dented a positive terminal on a Pila 168S while expermiting with a KL1 on a E2D. I never did get this combination to work either with 123s or Pilas and I tried two different KL1s. BTW I dented it by trying to use a small magnet on the positive end of the Pila in hope of making contact. When I clicked the switch it broke the magnet and dented the positive end of the battery.
I read that someone had repaired a dented Pila by carefully using a wire through the hole. I tried this without success.
I also tried solder. A very small blob worked but the solder broke off and would have to be soldered every time the head was removed.
I tried tinfoil, folded and super glued to the plastic around the positive terminal. This didn't make contact.
Can anyone tell me if liquid metal is conductive?
Any ideas?
Thanks /ubbthreads/images/graemlins/hahaha.gif /ubbthreads/images/graemlins/ohgeez.gif
Any ideas?
