HOW TO TOGGLE BETWEEN L/M/H
sled207
Hey Guys
Planning and buying parts for my first P7 build. Planning to power a "C" bin with a single LiOn and a SB 3 mode driver. My question is: How do you toggle between l/m/h with the standard Mag switch?
Thanks
Usually drivers are programmed to change modes using a "fast click". Meaning you turn it on, and if you want to change modes, you turn it off, than back on really quick and it should change from Hi, to Med. If you want to go from Hi to Lo, click it twice. This mode selection is linear and is extremely common for flashlight drivers.
Good luck with your build and :welcome:
you will not need to click on all the way, simply depress the switch up and down until you are on the mode you want then click it down.
If you leave it in that mode it will be in that mode the next time you turn it on due to memory function.
Thanks,
That is kinda what I thought, but then the memory function threw me. Turn it off and then back on and it remembers the last setting. I thought maybe you just pushed the switch half way down and up without actually clicking to the off position.
