65535
Can HSS work on Titanium or is carbide required. Workpieces are .375" 6Al4V titanium bar stock. Also are cobalt steel drill bits the way to go?
David,
There was some comment on G-771 on Practical Machinist, December '08. Sounds like some great stuff. Where do you buy it (McMaster shows Anchorlube but doesn't state G-771, Fastenal only carries 8 oz bottles).
The operations will be done on a Taig Micro Lathe II using collets and indexable carbide tools. I will be boring out the bar to fit the tritium tubes then either drilling or milling holes or slots .............
http://littlemachineshop.com/products/product_view.php?ProductID=1680&category=-1550042347
or
http://littlemachineshop.com/products/product_view.php?ProductID=3417&category=-1550042347
I honestly can't find the difference between those inserts. The one doesn't list corner radius but otherwise they seem identical.
Both the inserts you link to have 'C' as the second letter in their description.
This means that the FRONT clearance is 7° , but this sadly says nothing about the TOP RAKE which I suspect is neutral AT THE ACTUAL CUTTING EDGE.
The minimum running minutes, which you'll see when running maximum DOC, maximum SFPM, maximum IPR (which usually means a high horsepower machining center) is 20-25 minutes. If you are running a high hp spindle with CNC controls & manual tool change, double that to 40-50 minutes. High hp plus manual controls will get somewhere over an hour.I can't say how many surface feet of cutting is expected from a modern coated carbide tool.
sounds to me like I should crank the speed ... and shave the Ti rather than try to cut it.
