Gryloc
I discovered just how much this stuff sucks after I had an accident with one of my projects! I was cutting some of the heatsink material from my 18 K2 LED headlight cluster and then I later set it aside to finish tomorrow. I was pulling the cord to my soldering iron out from behind my desk when it snagged one of my clusters and caused it to fall face down onto my hard floor from about 2 feet. I was angry about this at first, especially since one of the LEDs were physically damaged, but this only uncovered another huge problem. I hooked up some power to this cluster (the way I usually do), and quickly, a few banks of LEDs turn off. Arghh. I have seen this before and I have already replaced some of the K2s already, so I know this is not anything small.
I hooked up a little battery pack to each LED and found that 3 burned out (the ESD diodes are damaged and ended up causing the whole LED not to light) along with the physically damaged LED. That is 4 more LEDs than what I wanted to replace.
Now why I posted this. I used the Arctic Alumina thermal epoxy to adhere each LED to a copper plate. I had confidence in the epoxy to electrically isolate each LED properly. I trusted it and it let me down. Some of the slugs (actually almost all of them) are electrically attached to the ground (the copper plate). There is little true electrical isolation at all between the slugs and the copper plate. I have been wasting my time and money all along.
I feel very bad about my friend whom I am making this for. This problem is so extensive and will take so much time (and money even) to fix, that I may never get to it by the way I am so busy with class-work.
It is so much work to remove a damaged K2 from the cluster and then prep the surface for the replacement LED. I do not know if I should start from scratch to ensure that each and every one is isolated and have properly working ESD diodes. I could apply a thin layer of nail polish to each LED first, or I could try to find star hex boards to isolate the LEDs. I am afraid to mix methods of truly isolating each LED and depend on the AA epoxy, so do I continue replacing each LED and just epoxy them, or should I re-work everything and try to isolate every LED?
This is so frustrating. If anyone has any ideas or comments, please leave them. I hate venting on the CPF, but this is something pretty major for me as it can cost me too much money. My friend payed for all the parts except for a few replacement parts. I might as well pay him all back and try everything from scratch. Anyone ever get in a strange situation like this? There are few people around here who are making automotive headlights, so it may be difficult to relate. Thanks you all for your help!
-Tony
edit: see my next post...
-Tony
