Big_Ed
Over the weekend I was up in Northern Wisconsin visiting a buddy of mine who owns a drive-in theater. I worked there last summer, and used my Surefire L1 every night with really good results. Since the end of the season in October, I have acquired several more Surefire flashlights. I figured even though it was well below zero degrees F last night, it was the perfect opportunity to play with my newer lights and compare them all. Sorry, no beam shots.
The lights I compared were (in no particular order) 6P with Malkoff M60, E2DL, G2L, L1 Cree, E1B, E1L, and E2L. I compared them all with each other in two different eyeball tests, ranking them by throw and spill.
In the throw comparisons, the target was the drive-in screen (talk about BIG white wall hunting!). I stood in front of the snack bar and aimed at the screen, a distance of approximately 310 feet. I ranked the 7 lights by apparent brightness of the spot each one put on the screen. Ones with multiple brightness levels were tested on high.
Throw results from brightest to dimmest:
1- E2DL, hands down!
2- 6P with Malkoff M60
3 & 4- E1B, tied with E1L. Both appeared identical.
5- L1
6- E2L (just barely dimmer than L1)
7- G2
As for the spill comparisons, I aimed each light about 10 feet or so in front of me and determined the brightness of spill at or near my feet.
Spill results from brightest (or most usable in my opinion) to dimmest:
1- 6P with Malkoff M60
2- E2DL
3- G2
4- L1
5 & 6- E1B tied with E1L. (both had just barely less/dim spill than the L1)
7- E2L (barely less than E1B and E1L, I think because it is slightly dimmer to begin with. Spill was the same size, though)
I know these comparisons are very unscientific, but it gave me an idea of which lights are best suited for outdoor use depending on if I need throw or spill. Numbers (like lumens) are one thing, but actual use is even better for determiningoverall usefulness. I also shined these lights into the woods surrounding the drive-in. The E2DL was outstanding! It has a very slight warm tint, which made the trees a bit easier to see than the Malkoff, it's closest competitor.
Too bad it was so cold. I would have really enjoyed playing with my lights all night. Oh well, I'll just have to wait till next summer!
5- L1
7- G2
2- E2DL
3- G2
4- L1
