Every Flashaholic also *must* at least try a SureFire A2 Aviator, be sure to give it a fair chance, it's a light that needs time to be appreciated, give yourself at least a week or two with the A2 before making final judgement, it's not meant to "WOW!" you in any one category, it's just a great, well balanced *tool*
3 lumen wide, floody LED beam (roughly 20 hour runtime when run exclusively on LED), the LED beam is just right for 80-90% of the usage of the A2, it's just the right amount of light, choices of models with a red, green, blue, yellow/green or white LED ring
"50 lumen" (actual measured output is mid 70's or so) *REGULATED* incandescent beam, very clean, white light (color balanced around 3000K), and the beam *stays* that brilliant white for the entire 50 minute run of the batteries, when the batteries can't drive the incan bulb, they still have approx. 25% charge left and will still run the LED's
the incan regulator has a "soft start" feature which slowly ramps up the voltage to the bulb during the first 50 microseconds or so, greatly increasing bulb life
the A2's 2 way switch is a work of genius, push the momentary button lightly for LED, push all the way for incan, or twist the tailcap for the same setup, first position is LED, second is incan, if you don't need the incan, you can turn the tailcap just enough so you can use the momentary button to illuminate *only* the LED ring
here's an example, two SureFire lights, on the left, the "50 lumen" A2, the right, the mighty 120 lumen P61 bulb.....
yes, the P61 has a larger hotspot, but which one is *whiter?*.....
now's a great time to give the A2 a try, with all the new Cree lights on the horizons, there are a lot of A2's up for sale and trade in the B/S/T section of the website
i'll never sell mine though, it's my EDC, i'm never without it.....
