I need a little help please.
waddup
i recently killed my spear clone R2 emitter
KD SKU: S006094
i dont have the soldering skills to re connect a driver, but i can solder a direct drive. (badly)
i need a recommendation for an emitter that is safe to use direct drive on a freshly charged 3.7v lithium..
and that will work ok with the spear clone reflector
id prefer to buy from a usa based company to avoid the 4 week wait.
shining beam has a few bare emitters.
any help appreciated.:candle:
I'm very satisfied w/ the R2 I got from Shining Beam, nice neutral white and good price. I picked up a Q3 5A warm tint too, looks great in my MiniM@G.
is it ok to run that emitter direct drive on 3.7v?
it sais 3.5v on shining beams site.
Where are you? I can help you out with re-building it if you happen to be close to Kingston.
Putting in a driver is no harder then swapping an emitter. Infact, I'll say adding a board is easier.
You're saying you blew the led, and there was no driver to start with?
http://www.candlepowerforums.com/vb/showthread.php?t=243439
its a thrower, really doesnt need to be multi mode, single mode direct drive will work, altho i am thinking about putting an mc-e in there just for ghits and siggles.
no idea what the mc-e would do to it as a thrower but im guessing it would 'throw' a lot of light and flood some?
re: mc-e usually that means there'll be a donut (dark spot in the middle). The mc-e isn't a throwing die. The center of any hotspot is vacant on the die (the intersection of the 4 pads). So to make a nice even beam the light has to be diffused, and diffused light is obviously not concentrated and thrown.
Wire up the mc-e and stick in in the reflector (before attaching to your light) you'll see what I mean. It's just the nature of multi-die leds. You want throw, it must be single die. (maybe you just have to try it to see how that all works. I had my doubts, thought I could find the way. I didn't)
i have a couple of throwy lights, i dont mind if this thrower becomes more floody, and artifacts in beams dont bother me as i only use my lights outdoors at night.
i would like to be certain my new LED will be safe to use on a freshly charged li-on (4.2v) tho?
which one?
Yes, you can run an emitter direct drive. As long as it has a decent heat sink....the voltage usually sags a bit when power comes on...and 4 volts gives a nice bright light!
the original R2 didnt like 4v much :poof:
which is why im looking for new parts :ohgeez:
your like me, i have to find out myself before i believe.
its the only way to understand.
i have ordered a P7 :D
