onetrickpony
- Joined
- Mar 10, 2011
- Messages
- 262
Hi, just looking for the best way to drive a light I'm building for my wife's uncle. It will be powered off of the 12v lead acid battery that starts up the motor and powers a few other electronic devices.
I have two ideas, tell me what you think:
1. Single sst-90, either direct drive with resistor or underdriven by a 6.5A 5 mode driver I have lying around.
2. 4 (or more) XML's direct drive with resistor or with a driver. I like simple and durable.
Here's the rub, I have a really nice improvised heat sink, some 75 mm glass aspheric lenses lying around (probably going to use just one) and I really don't want to go crazy buying parts, so cheap is very good.
I have a theory in the back of my head that running more LED's at the current that gives the best lumens per watt to achieve the desired brightness is better than running one LED at a much higher current. First off, longer run time off of the 12 v lead acid battery, and second, way less heat and damage to the components.
If anyone has done something like this successfully, what did you do?
EDIT: PS, I really want this thing to be amazingly bright, this guy has helped me out a lot over the years, and if the only way to do it right ends up being kinda expensive, that's ok too. I'm looking for between 2 to 5 thousand lumens, and the ability to light something up as far away as possible, I can probably come up with a way to focus the lens from spot to flood so it's more about the raw lumen output.
One more question, how much efficiency will be lost if the lens is out of focus or if I go with multiple led's under a single lens, meaning that only one is at the focal point of the lens?
Thanks again....
Thanks again....
