Anglepoise
A post from precisionworks around six months ago got me experimenting with inserts designed for aluminum. By selecting a grade that works with other metals, I don't need a large number of holders or inserts.
This insert grade works perfectly with Aluminium,Stainless steel and Titanium.
Its H10, polished and ground, no coating fine grain carbide.
One style chipbreaker , high positive 25° at tip, 20°on side. Positive allows little stress on the part being machined and very light clamping in chuck will hold parts well. Designed primarily for machining aluminium, but works very well on SS and Ti.
Chipbreaker syle is AL
Triangle shape with three cutting edges. Economical yet triangle shape is strong enough for most of my work that would be classified as ‘finishing’.
( Use any shape insert you like that is available from your supplier. The key is grade and chipbreaker )
