Well, perhaps not, but I definately could use some help.
This could be stupid, obvious and all sorts of annyoing things but I seems to have some kind of problem with learning if I don't get to try, fail and retry on my own. It turned out that flashlight modding was no exception to this.
So, this is the situation. I have a small flashlight I wish to pratice modding on. My goal with this project is not to create the optimal super light of eternal youth or to save cash or anything, my goal is to learn how to succesfully make a working custom solution. Of course it would be cool if it outperformed the original setup but I'm prepared to consider such a success a bonus (even though I could imagine that one doesn't need too much success to outperform the standard config).
The flashlight is a cheap $8 thing with head, body and clicke switch housing constructed out of alumnium. It runs on three (3) AAA batteries clicked into place into a plastic battery holder taking up virtually all space inside of the body. The light source is 14 white LED soldered onto a circuit card/board which is inserted into a plastic, cylinder shape reflector (looks like a salt shaker lid) and held together in it's space in the head by a retention ring made out of alumnium. Now, would the following plan of action work at all?
1. Construct and make a custom pill designed for snug fit above a single CR123 battery in the body? The specs of the pill would be 23 mm in diameter and a height of (maximum) about 35 mm. Is this to small? Too large? I chose the 123-solution instead of keeping the original battery holder since there is only about 3 mm of free space if I choose to do so. I guess a good emitter and smart parts in the pill could compensate alot so using just one 3V lithium cell wouldn't be a bad choice compared to 4,5 V (through 3*1.5v AAA)?
2. Construct and make some kind of skeletonized battery holder / side padding for a single CR123, this might sound like over-kill but I need to do something since a standard 123 is too small (thin) too fit well into the tube, as for now it'll just lie there, loose and shake around. Or will it? Maybe it can be held into place by the pill designs natural pressure against the battery?
3. Replace the reflector with a new one correspondent to all the measurements of the head and the pill (LED-size).
4. Replace the lens, mostly for fun I guess but the scratched up plastic original is probably not that hardcore and perhaps I need to switch to a better plastic or even glass? I don't know how much heat a good emitter could produce in a construction like this.
5. Decide wether to keep the original switch or change it, perhaps to a traditionall one instead of a reverse. Regardless of what this isn't a big part of the project and shouldn't be of any significance to the rest of the plan.
Ok. So the first thing I need is some feedback on my plan. I don't need feedback saying that it's too much, ain't worth the parts and expenses and so on cause like I wrote earlier I'm not into this to save money or find an easy sollution to make the light brighter, then I would just buy a better flashlight.
I want to construct some kind of pill and make a few other alterations with the sole intent to learn by doing. I need to know if my plan could work out, if and how I should alter it and so on. Then I can go on with the next step, scouting for info on what parts I would need to construct the pill and how to assemble them, after that I could do the rest pretty fast. Err.. this could probably be further discussed...
NOTES:
-The flashlight have no known name but it's made in Hong Kong
-The flashlight is very similar to MrBulk's GoldMine mod
-My flashlight is available from Electronic GoldMine aswell
-MrBulks GM mod is too smart for me since one of my goals is to learn how to make a custom pill, by making one.
Thank you!
NOTES:
Thank you!
