I want a 32lumen per watt halogen bulb
blasterman
Reading through the automotive forum here I'm seeing claims that halogen bulbs in autmotive stores have claimed outputs of 1600lumens at 55-watt and 2100 lumens at 65-watt.
So, why can't I get a 2100 lumen / 65-watt lumen Halogen bulb at the local store?
I also maintain a ton of legacy DJ fixtures that run off 12-24volt bi-pins (some as high as 650watts), and none of them spec as high as 1600lumen / 55watt or 2100lumen / 65-watt.
Why can't we have this new Halogen technology in fixed lighting? I mean, 32lumens per watt is pretty darn good for Halogen.
I expect it is due to longevity. The ultra high efficacy (+80/+90) automotive lamps have Tc times (the point where 63.2% of the lamps have failed) as low as 350 hours. The average consumer expects their light bulbs to last longer than that. In fact, one of the things usually advertised on the packaging of halogen lamps sold for home lighting is increased lifespan over standard incandescent. However, I agree that it would be nice to have lamps available for fixed lighting use that were similar to the ultra high efficacy automotive lamps. Even though they would probably have to be low voltage to get acceptable lifespan, they are more efficient and whiter, because they run the filament hotter.
Phillips Xtreme power -vs- 100watt Incan
I appreciate the thoughtful response, but I don't think it's true. Halogen technology is halogen technology. You can tweak noble gas ratios all you want, but power in = lumens out. If you want more light you need to increase the wattage of the bulb and hence less resistance. You can increase the longevity of a bulb by decreasing required voltage (and hence intensity), but I'd like more proof that the opposite direction yields the opposite results. HIR claims yields 10-25% increased intensity depending on who you read. I believe HIR drops in efficiency as the bulb wattage gets higher.
Anyways, I decide to test this with the much bragged about Phillips Xtreme power automotive bulbs -vs- the same 100watt / Incan in my prior test. I mounted the Phillips on a tripod, and powered it off my 400-watt computer PSU molex while monitoring voltage. I noted and confirmed the Phillips throws more light backwards 120 degrees, and compensated for this by raising my tripod about 30 degrees above my test target. This gives the Phillips the best possible light intensity on my target. I then shot comparison pictures with my dSLR. Shots were taken with my 50mm 1.4 wide open manual to negate any theoretical aperture or camera deviations, and converted in RAW at 3500k.
Visually the Phillips wasn't even close to the out-put of the 1600 lumen Incan. I made a third shot at half the exposure with the Incan to prove this. During the Phillips test my voltage dropped to 11.7volts, which is a tad low. However, consider I measured the Phillips at the brightest point in it's non-uniform light cone which would push the total lumen count even lower (??) The Phillips was identical in color to my over-head 50-watt halogen track lights, but whiter than the Incan.
So, unless I'm drastically under-powering the Phillips, the lumen and efficacy claims of these type bulbs made in the autmotive forum are complete and utter bunk and significantly below 1000 lumens. It doesn't tell one way or the other if the Phillips is simply better than standard automotive halogens or has better light directivity, but it does prove the Phillips works at about the same efficacy levels of good household halogens. For $50 a pair I expected gold plated tins though :rolleyes:
Left / Phillips: Middle / 100-watt Incan: Right / Incan at half exposure
@Blasterman:
The reason why lower voltage lamps can have longer lifespans is because the filament is thicker for a given wattage. Therefore, more of it has to evaporate before the filament breaks (I know the halogen cycle redeposits the tungsten on the filament, but it does not do it perfectly evenly).
Regarding lumen output of your Philips Xtreme Power lamps, I believe the Europeans (Philips is Dutch) rate their lamps at 13.2V. Brightness is exponential to the 3.5 power with voltage, therefore a 1.5V (13.2-11.7) drop is significant. What type of lamp is it?
how can you prove lumen output without an integrating sphere?
auto bulbs are rated at the common 13.8v and 11.7 may represent a 50% loss but much longer life.
yes the automotive gimmick super bulbs have a rather short life.i have seen some speced at 500 hours or less.to make things worse they loose light with silly blue coatings on some.
That's like saying I can't make accurate exposures with my dSLR unless I have a grey card.
You really think results are going to be different if I shove a piece of plastic plexi between both the Phillips and the Incan? :nana: The relative intensity measurements will be identical.
It's a very expensive Phillips Xtreme power. I'll have to get a variable power supply and see how voltage affects lumens myself. However, while I may be playing semantics, the bulb states '12-volt', and not 13.2. I realize that car voltage circuits aren't exactly precise, but the bulb states '12-volts'. If the bulb doesn't get it's astronomical lumen ratings at 13.2 volts the car nuts will then tell me I need to upgrade my wiring harness, or I need a german made alternator, or something.
Thanks for staying with this one in any case and keeping me on my toes:thumbsup: The car guys are like arguing with audio enthusiasts who buy $500 interconnects and make up physics to justify them.
Blasterman, you may think that running a halogen bulb hotter does not make it more efficient at generating lumens, but it is just a well known fact for black body like radiators.... to a point......when you start getting into the blue/UV when again the LUMEN output drops.
You are correct that power in = power out, but power out is not the same as Lumens out.
The output spectrum changes significantly as the filament gets hotter and that significantly drives the lumen output. Power in = rada
Yes the bulb says 12V, but that is as opposed to 6V, or 24V, it only indicates the system voltage. However, the test voltage will be higher. Higher voltage equals significantly more power equals an output spectrum that produces more lumens.
I assume you are also measuring voltage at the bulb, not the power supply?
SLRs (cameras) make poor light meters. The action of white balancing changes the relative contribution of the collected colors of light. Unless you are working with two lights with very similar spectrums, then the relative measurements will not be accurate. For what you are measuring, it may not be too bad. The other error that creeps in is gamma ... which can compress differences in brightness.
Semiman
even if there is no adjustable power supply available, are you able to measure the current flow through the 12v halogen lamp? that would help getting a better estimation of its efficiency.
"how can you prove lumen output without an integrating sphere?"
I'd think it would be possible to use a quantum flux meter made to measure 550nm radiation and some complicated equations to convert into lux.
No debate there. The million dollar question is how much voltage would be required to get the advertised lumen value and why won't anybody answer the question and stop making countless excuses for the Phillips marketing dept.
A 100watt bulb puts out a fairly standard lumen ammount which is also the claimed out-put of the Phillips. When measured head to head at 11.7 volts, the Phillips couldn't put out half the light. The question is, how much voltage would be required for the Phillips to match the Incan. I'm guessing it's a lot less than my Mazda. I'm also guessing adding .3 volts to the Phillips won't make it twice as bright.
If I take two shots at manual settings, and one shot is brighter than the other, it's safe to assume that the brighter shot has more lumens. Or, maybe it's a secret algorithm built into my Canon to bias shots against light bulbs, right? That's what they'd say in the car forum here.
Also, any variable you applied to the 12volt bulb I can apply to the 120volt bulb. Natually though only these discrepencies apply to the Phillips.
Both the Phillips and the Incan are 360 source emitters. If a single point of that projection spehere is measured for reflected light, then at a minimum you have a relative measurement of lux. The difference in color temp between the two bulbs is also not a significant factor. This a 55watt frikken bulb compared to a 120watt bulb, and you guys are making it sound like the emission differences between my 250watt metal halide.
Doesn't matter. I can't convince you guys that the Phillips was putting out less than 1/2 the lumens at 11.7 volts, so there's no base reference.
Even if I measured the current, excuses would be made that the device was broken or not polarized in the horizontal plane or something :wave: Actually, measuring resistance during running would accomplish the same thing.
My tests confirmed the Phillips is no more efficient than any other 12volt halogen bulb, nor brighter, nor uses some magic technology. The only variable is how mugh better the Phillips behaves at higher voltage levels, and we can't prove #B if we can't agree on #A.
I'm sorry to say that, but your tests actually confirmed nothing, because you just simply can't compare different bulbs running at a different wattage. grab a multimeter and a laboratory powersupply, and test this magic philips bulb at the same wattage as a standard halogen bulb. this way, a comparison would make sense.
He was comparing a standard 100W A19 incandescent like many people use to light their homes, to a Philips Xtreme Power lamp used in car headlights. He hasn't said which lamp from the Xtreme Power line he was using, though.
I'm assuming you're referring to H7 here, and the rest of the time where you discuss the Phillips Xtreme Power without reference to bulb type.
Yes, 1600 lumens at 13.2V from a bulb that nominally runs 55-watts at 12V and is tested to a maximum of 68W at 13.2V.
Which isn't 32lm/W, it's 24 lm/W. Yeah, it's kinda confusing, but that's what happens when you regulate bulb types, and then manufacturers try to compete while conforming to those specs.
Because the bulbs you get at the local store have 2000h or more lifetime, whereas the Phillips Xtreme Power gets something like 300 hours. Astonishingly, most people would rather pay a bit more in power to match the output with a higher wattage bulb than pay 7x as much because their bulbs keep burning out; as a result, nobody even tries to sell high-efficiency (=short-life) halogens.
But, actually, some bulbs come close, if you're willing to drop to the 50-100 hour range. Look around, for example I found FCR bulbs which make up to 36 lm/W -- for 50 hours. Apparently intended for dental applications, so you won't find that in your local store.
No, because general lighting bulbs, unlike regulated types for automotive lighting, are rated at what that bulb can do, not at some evil hybrid of what the bulb type is nominally specced at and what that particular model can do. The lifetimes needed for real 32 lm/W are too short for most practical applications.
Yes, it is, but it's not new technology, just bulbs driven hard for a short life. And if you overdrive a 64447 IRC (4000h 65W, really new technology) to ~14V for comparable bulb life, it handily exceeds not only the 24lm/W the headlights should be making, but also your figure of 32 lm/W. Sucks that there's no high-output IRCs to run in a stock 12V fixture, of course, but there's life for you.
Because it's a question about automotive bulb specifications, and this isn't the automotive forum, so nobody knows. As two people have tried to explain, automotive bulbs are tested for power and output at 13.2V under the ECE system, and it's likely (although not 100% clear to me, as DOT spec is at 12.8V, and you haven't even mentioned what bulb type you're testing) that the lumens ratings come from that 13.2V spec. But instead of listening to their best guess, and if you don't believe them digging into the ECE and/or DOT specifications yourself, you simply responded by blathering on in ignorance of automotive electrics and the specifications pertaining to them, with the disclaimer that it "may be playing semantics". And then come back with the claim that nobody will answer the question.
:huh:
Well, adding .3V wouldn't but since nobody tests automotive bulbs at 12V (and nobody runs them at that, either, unless your wiring is bad enough to drop 2V under load), that's pretty irrelevant. Going up from 11.7V to 13.2V is an increase of 13%, and should get about 50% increase. Given that this would account for half of your observed discrepancy, it certainly seem worth a try?
Actually, they wouldn't. They might say, as others in this thread have, and I'm about to, that for similar spectra (and yes, these should be similar enough) and radiation patterns (less clear, but probably close, and you said you were taking the conservative measurements using the bright portion of the 12V bulb's beam), a direct which-is-brighter comparison using a camera is valid; however, using a camera to determine the ratio of flux by the ratio of image brightness is not valid. The one way you could do a valid comparison is to vary exposures; if you use half the exposure time for the brighter one, and the image is still brighter, then that's a valid demonstration that it's more than twice the flux. Since you did this, I really doubt you'd find any credible people claiming those results are wrong. (If you read what semiman wrote instead of knee-jerk reacting, I think you'll find that he said the same thing -- that gamma prevents ratio measurements, and that the spectra you're using here are probably close enough for reasonable over/under results.)
No, not really, because mains lighting isn't driven off an alternator at 144V and isn't known to be tested at either 132V or 128V depending on regulatory regime. So your fundamental lack of knowledge on the automotive side of things, which is what led you to the erroneous conclusion that these headlights claim 32lm/W in the first place, isn't really a factor with the 120V bulb (BTW, I'd somehow been operating on the assumption you were trying this vs. a 12V 100W halogen -- now you say 120V bulb. I guess I'm not seeing a clear statement of 12V now, so maybe I'm just confused...)
But since you mention it, some points do apply -- you measured the voltage you're feeding the automotive bulb, what about the other bulb? Line voltage is typically specced to +/- 10%, so if it's a 120V bulb running direct, or a 12V bulb running on a transformer, similar variation is possible; OTOH, if it's a 12V running from the same PSU as the automotive bulb was, it probably sagged even more under the higher load.
If it's overdriven, that (in conjunction with the known underdrive on the auto bulb) could explain the factor of 2 difference in brightness.
If it's similarly underdriven (which would be about 10.6V), then we know something is as mismatched as it appears here, and you would have data to argue with those who disagree, instead of straw-man accusations.
If you read posts a little more carefully, you might find that most of us simply aren't disputing that it's less than half the output -- at 11.7V. We just realize that underdriving a high-output bulb horribly, comparing it to other bulbs, and concluding it's junk is ridiculous.
Yes. Of course, I'm not aware of any way to measure the resistance without disrupting the bulb's operation other than measuring the voltage and current -- either there's you know some bit of metrology I've missed (in which case, please share!) or your suggestion is rather useless.
As for the rest, yes. Absolutely. Because we're all on Phillips's payroll or something, so we're just going to sit here concocting rubbish excuses until you sit down and shut up. (Except not really -- do you realize how childish it sounds to claim we and/or the automotive people would respond in all these bizarre ways?)
:wtf:
Your tests confirmed that, when horribly underdriven vs. 13.2V spec, the Phillips is not more efficient than another bulb presumably driven at 12V spec. Which makes your tests a waste of time, because anyone could have told you to expect that. What you've "confirmed" is what everyone else knew -- there's no magic technologies involved, just good ol' driving the filament so hot it doesn't last long. If you do that to a long-life bulb, it's overdriving; if you build it into your bulb design, it's not. But the physics are the same, and it's exactly the expected outcome.
Also, if you get an adjustable power supply, and crank the phillips bulb to 13.2V, then crank the other bulb to the same 13.2V, it'll still be twice as bright. As you've observed, no magic, just all halogens being more efficient when driven harder. Again, no tests needed -- this was common knowledge.
The only "magic technology" that does exist is IRC; it's real, it works, and will improve efficiency at the same drive point. But that's not used in the Phillips Xtreme Power bulbs, and nobody said it was.
You don't 'drive' a bulb harder. The bulb is rated for a specific voltage and indirectly hence wattage. Automotive circuits don't 'detect' a specific bulb and 'drive' it harder. Automotive circuits aren't current regulated as far as I'm aware.
Yo jtr1962, can you step in and perhaps confirm this for me?
Glad you admit it. That's about 90% of my arguement. Now get the automotive forums to admit it. There's a couple of you over there in the automotive forum that make a pretty big deal over these bulbs being brighter first, but will only admit the shorter lifespan if pushed. Care for links?
If I bought a bulb based on somebodys advice, and they neglected to tell me that the bulb has 10% the rated life, and my gf was driving the car on a trip when the bulb burnt out because it has 10% the lifespan and hence she got in an accident, you better thank your stars I can't find you in person.
For somebody basically calling me 'stupid' why do you keep using the term 'Drive'? Can you outline how an automotive circuit actively 'drives' a lightbulb? Gee, I thougt it was just classic resistance because it's not current regulated.
Also, this trick has been used in incan bulbs for decades. By over-volting the bulb a bit you can drastically increase it's lifespan, but resistance is higher and lumen out-put is lower.
So, the Phillips is basically performing the inverse of this, correct? That means, the Phillips isn't really a 12-volt bulb, but a 11 or 10 volt bulb. Or basically, it a lower voltage bulb than a generic at any standard you wish, correct? Either that, or it's not it's rated wattage. Either way it's means the product is guilty of false adversiting.
If so, why can't I do this for incan bulbs? You know, rate the bulbs for 100 volts rather than 120 and just have the bulbs made in Europe and charge 7x the price claiming they are brighter? Get a quasi 'world' commision to approve the 100volt spec, and off I go. Claim American specs are wrong and not up to guidelines. Am I close? Oh yeah...that bulb won't last nearly as long at a regular 120volt bulb, but you didn't ask that.
What I've been getting at.
I would go by DOT specifications first, and the bulb clearly states '12 volts' on the package. I understand that in reality car voltage systems are higher / more variable than this, but the bulb jacket says 12volts and doesn't state an ECE guideline. That's why I assumed 11.7 volts was close enough. I didn't realize the ECE dictated light bulb technology. For the record, my old Acura measured 12.4 volts off the harness because I used to power up portable lasers. Of course, that's a Japanese car.
Cool - saves me some testing. Actually, I would assume the Phillips has a mildly different composition that might theoretically give it better re-migration properties resulting from a shorter filament and hotter temp. However, they won't amount to "80%" brighter and justify a 7x price increase just because it's made in Europe. A shorter filement in the generic bulb would likely result in the same thing.
Again, how does an automotive circuit know how to 'drive' a bulb harder whilst calling me stupid?
You've already agreed that the Phillips wouldn't show {much} of an advantage over the generic bulb at the same wattage, so there's no reason for doing such.
Also, it's predictable that you'll make an excuse for when I can't find a consistent automotive spec showing 13.2 volts as being constant. Obviously the only cars that will prove such will be European. Or, I need to replace 5' of wiring on my car..... which won't account for nearly the voltage difference along any conventional guideline. Oh wait...I need to have a European car with European wiring. Hey, it's the what I see keep being claimed in the automotive forum, so don't bash me.
[The question is, how much voltage would be required for the Phillips to match the Incan. I'm guessing it's a lot less than my Mazda. ]
:huh:
Oh, I forget. Japanese aren't genetically capable of making lightbulbs and cars up to European Arian standards. The Phillips is of course a german bulb.........
You mean, my apathy towards ECE specs, along with most Americans who don't get goose pimples when Eurpoean engineering is mentioned. Also, I'm not the one using the term 'drive' on automotive car circuit that I don't think is current regulated.
The Phillips bulb is either not a 12volt bulb compared to generic 12volt bulbs with much higher lifespans, or it's wattage is mis-represented. Somehow, this makes me "stupid" though because I don't allow the Phillips to totally misrepresent itself using ECE specs as an excuse.
Problem is, this isn't stressed (at least until recently) in the automotive forum here. If it were, I wouldn't have brought it up, and I'm sure as hell most people wouldn't by this over-priced junk except for a couple of you pushing the bulbs and failing to state their poor lifetimes.
Instead, you keep blathering on about ECE and European engineering standards and how the rest of us are wrong. Actually I think the proper standard should be minimal lifespan of the bulbs because this would seem to be a severe safety hazard. However, since European regulations are stroked to protect competitors and not consumers (fact - not my opinion) that would only likely happen in the U.S.
Also, how I reply to another poster is really no concern of yours, and for the record, 'aluminum' is pronounced with 4 syllables and not 5.
The only circuits that MAY make some attempt at regulation are PWMed circuits on newer cars. But none are able to detect a particular bulb, and adjust the voltage and/or current.
Now getting to the main point of your argument ( on which I agree ), if it says 12V on the package, then it will be assumed by any reasonable person that this is the voltage where the bulb makes its rated lumens. If the bulb must be driven harder to obtain the rated lumens, then the package should say 13.2V, 13.8V, whatever. To do anything else is misleading. It's like taking a Cree XP-G R5 bin, saying it's rated at 350 mA, and then also saying that it outputs 345 lumens. Yes, it does, but most definitely not at 350 mA. Same situation here. Either give the lumens at 12V, or tell us how many volts are required to obtain the rated lumens. But do it on the package. One shouldn't need to go to ECE regulations and do math to figure out at what voltage the light bulbs they just bought output rated lumens.
Second, unless the Philips bulb uses IRC, which is doesn't, it's not going to be significantly brighter at any given power consumption unless it runs the filament hotter than generic bulbs. And if it does, then it'll obviously have a shorter life. Now Philips might perhaps use better manufacturing techniques ( maybe that justifies part of the price?) to mitigate the lifetime penalty somewhat. However, it will still have a shorter life than a generic bulb running a filament at a lower temperature.
Anyway, my two cents after following this thread a while. After being in the electronics industry for over 2 decades I've never seen such a case of misleading specs as here. Most parts, whether ICs, LEDs, MOSFETs, etc. have a clearly stated set of conditions where they meet their specifications. Not so with these lamps. Rated voltage doesn't give claimed lumens, and claimed lumens are only obtained at some unknown voltage not clearly marked on the package.
Except that nobody in the automotive section at wal-mart would know the 12.8V or 13.2V bulbs being sold are for their cars, because "everybody knows cars have a 12V battery"...
Sure, they should probably add more information about what voltages are expected to gain the lumenosity and life claimed, but Joe Walmart doesn't really care about that sort of thing.
It is threads like this that at times make me wonder why the heck I come back to Candlepowerforums.
Blasterman, get off your high horse. Your initial test as pointed out was worthless and you keep flogging an inaccurate and quite dead horse as Benson tried to point out being as nice as he could be and probably pulling most of his punches.
People who deal in Automotive know that 12V or 24V for that matter is simply a "nominal" system voltage, they could have used A and B, but 12V and 24V is more descriptive sort of like how we call NiMh 1.2V, even though they can be 1.4 fully charged.
N.A. standard test voltage is generally 12.8V for rated performance keeping in mind that the voltage can be higher or lower. SAE specs do set maximums (and mins). The min generally must be met at the test voltage (though can be lower), with the max not exceeded under normal operating conditions. European testing is at 13.2V.
There is a significant difference in light output between 12.8 and 11.7V as has been stated earlier.
These are bulbs specifically designed to draw say 65W at 12.8W but run much hotter than normal bulbs. They filament design is different. It is not the same as 11.5V bulb ran at 12.8V to get a lot more light. A bulb like that would have even lower lifetime and be very susceptible to vibration.
Your initial proposition, watts in = lumens out is not true. That is only true at a very specific temperature of the black body radiator. Raise the temperature at the same wattage and the luminous efficiency goes up considerably. Same wattage = far more lumens out!
So, what you need to do is run your 100 watt INCAN and the Philips Extreme at known WATTAGES (rated) and not voltage which is not indicative of the filament temp. Then give us your results. Until then, stop trying to forward an inaccurate argument based on lack of knowledge and an inability to admit you are wrong.
Semiman
