It's easy to work out from thinking about how a reflector works, needless to say I only worked it out through experiment. A cresent shaped strip on the lens should obscure half of the hot spot. Easier to work with a larger diameter lens.
(After I post my pics I'm gone forever.edit i expect by end of month)
ha ha ha ha ha. It looked a lot better indoors than it did facing it on an open road. First test ride was dissapointing. Problem is there is still too much spill. It is better than nothing so I won't give up yet.
I've tried two designs, i'll continue to tweak them, maybe discover somthing else. One is a narrow (0.5cm?) horizontal bar somewhere between 1/2 and 2/3 of the way down the bulb, flat agaist the lens. The other is a reflector just below halfway that projects 5cm forwards and slightly down, maybe 75-85 degrees.
