illumiGeek
I've read a bunch of threads on this subject, but I had a somewhat different idea/approach to the problem. Search didn't turn up anything like this, so I thought I'd throw this idea out for comments, criticizms and suggestions.
How about running several used/spent 123 cells in parallel with a boost regulation circuit like a Mad Max? Seems to me this would solve (or at least improve on) the problem of uneven cell drain associated with series arrangements; and allow for a much brighter light than some whimpy 5mm LED or an ARC in moon mode. A parallel rig should let the MM suck the cells down to less than 1v per cell, and still give enough current to drive a lux pretty hard.
As a test bed I'm thinking about a C Mag body with a Mad Max, a nice low vf Lux emitter, and a battery adapter that links the cells in parallel. Should be pretty cheap and easy to build. A 2C body could fit 2x123 with a parallel arrangement. A 4C could fit 4x123 with room for the extra insulation and contacts needed for parallel.
So what do you all think of this idea?
