lothloriel
- Joined
- Feb 15, 2013
- Messages
- 3
Hi there candlepower!
For my light source I have some XPG-2 LEDs. Ideally I want to use 1 LED per coloured disc. Details as follows:
I have an odd sort of problem on my hands. For a project i'm working on I need to illuminate (backlight) a semi-opaque coloured disc (~30cm diam) with a relatively even distribution. I also need to illuminate it from the absolute shortest distance possible; im talking having the LED less than 10cm away from the disc.
This kind of stuff is not my background so I wouldn't know where to start.
I can only thing of 2 options off the top of my head;
1. use the widest reflector I can find (as of this post i've found an 80deg reflector from this website (does that 80deg mean from centre out? so 160deg across the diameter?)) and just shine that directly on the target
2. handmake/order a large flat parabolic reflector with a shallow depth and 30cm diameter, and orient the LED backwards into that reflector which then illuminates the target (Would normal aluminium foil work for this? E.g. create a skeleton in the shape of the parabola with wire and then fasten the aluminium as smoothly (or crumpled for diffusion?) as possible )
Could anyone offer suggestions how I would go about doing this; both in making any required reflectors or sourcing appropriate materials.
regards
regards
