www.imalentstore.com
IMALENT will launch the IMALENT LD70 in May 2020. This is a powerful, cool looking, and compact EDC flashlight.Using Cree XHP 70 second-generation LED light source combined with high-performance aura to provide a more powerful photometric output for the flashlight. The new LD70 uses a 1100mAh high-capacity and high-rate 18350 battery, which provides a powerful photometric output for the EDC flashlight and also guarantees the life time of the flashlight.
IMALENT LD70 adopts an improved design, and has been completely transformed from the inside out. This is the cheapest IMALENT flashlight. IMALENTLD70 is the first EDC flashlight with aluminum alloy protective cover in the history of IMALENT. The flashlight body is made of high-quality aviation aluminum alloy. The surface has undergone military grade three hard anodizing and wear-resistant treatment. It has IPX-8 waterproof standard and 1.5 meters drop resistance. The smooth lens barrel adds heat dissipation stripes to make the flashlight more comfortable
IMALENT LD70 has almost beautiful colors, black, blue and gold, and army green, and is designed to withstand the erosion of dust and water.
The outer shell of IMALENT LD70 comes in many colors, and the inner shell is black. OLED display and IMALENT LOGO on the front
The flashlight switch uses a metal key switch to make the flashlight switch easier and more comfortable. The flashlight is charged by magnetic force, and the flashlight has a hand rope hole for convenient daily operation.
What does IMALENT LD70 contain:
LD70 flashlight
Hand Strap
Charging Cable
manual
Packing box
LD70 flashlight
Hand Strap
Charging Cable
manual
Packing box
