IMALENT DX80 is a rechargeable LED flashlight. It is a 32000 lumens flashlight, 8 CREE XHP70.2 LED super bright flashlights, rechargeable searchlights, professional waterproof searchlights, which can maximize brightness and normal operation in various environments. Easy to use, search and rescue outdoors, enabling you to effectively plan and reduce the risk of dimness in darkness and storms.
IMALENT DX80 has high brightness and small size; with an output of up to 32,000 lumens, this flashlight illuminates everything
Six output levels + strobe (turbo mode: 32000 lumens, normal mode: 13000lm, 5000lm, 1500lm, 500lm and 120lm); DX80 can meet your expectations regardless of the terrain and environment.
OLED display, showing lumen output, voltage, charging status and overheating warning; the built-in OLED display will ensure that you will not miss any beats, and its status warning, mode output and other functions will ensure that you are always in full control.
Instant boost mode, press the pressure switch at any time; use Instant Turbo mode to light up the darkness! Reach the maximum output on the DX80 immediately, and with just one touch of a button, you can be sure you always have what you need.
Easy-to-operate tactical pressure switch; similar to Instant Turbo mode, our easy-to-use pressure switch ensures that you are always in control. A comfortable click will also ensure that you always get the feedback you need from a high-performance flashlight.
Rechargeable battery pack, including eight original IMALENT 18650 rechargeable batteries; our Imalent batteries are like flashlights and are the best in the industry. We want to know that our customers are safe, so please always use our Imalent battery and flashlight, this is the best!
IMALENT MS18 rechargeable flashlight, 100,000 lumens flashlight is the brightest flashlight. The lighting distance can reach 1350m. The service life is 50,000 hours. Great for camping, hiking, cave exploration, adventure and much more.
Super bright beam: Ultra wide beam can easily illuminate the whole room or backyard. Its brightness is 50 times that of car lights.
The nine settings of IMALENT MS18's brightest LED flashlight replace the need for multiple flashlights: (700lm / 2000lm / 5000lm / 10,000lm / 22,000lm / 30,000lm / 60,000lm / 100,000lm / strobe light).
OLED display: The digital screen of the bright flashlight will show its charge, and then we know clearly that the battery charge is still there.
Special design: Rechargeable flashlight, made of high-performance aluminum alloy. It is durable and almost indestructible.
"Monster Flashlight" IMALENT MS18 uses 18 American CREE XHP70 XHP70 second-generation LEDs, with a service life of up to 50,000 hours, a maximum output of 100,000 lumens, and a high lumen flashlight
Built-in switch indicator, easy to find in the dark Switch size: 265 mm (length) * 129 mm (head diameter) * 59 mm (body diameter) Net weight: 1900 g (including battery)
Built-in safety self-test intelligent charging circuit, convenient, fast and safe. Eight levels of fast switching and instant Turbo.
High-efficiency constant current circuit will maintain constant brightness.
The built-in thermal control module automatically adjusts the brightness output for comfortable use.
Combination of toughened ultra-transparent mineral and anti-reflective coated glass aluminum OP mirror.
Aviation-grade aluminum alloy body, wear-resistant type III hard anodized surface treatment.
IP56 standard waterproof
FREE
SHIPPING
100% MONEY
BACK GUARANTEE
ONLINE
SUPPORT 24/7
BESTSELLER PRODUCTS
FREE
SHIPPING
100% MONEY
BACK GUARANTEE
ONLINE
SUPPORT 24/7
BESTSELLER PRODUCTS
