gav6280
Could someone please explain to me as simply as possible what the various available bins are for the SSC P7 and what difference it makes?
Thanks.
Thanks.
The basics of the P7 binning are;
Example: DSWOI
The D is for the luminous flux, the output in lumens.
"D" is the highest output rating currently available. This means the
LED tested at between 800 and 900 lumens. There is an "E" listed
on the spec chart, but so far they don't exist. "C" is 700 to 800.
My own light has a C in it and I don't see much difference, though the
difference between C and D could be anywhere from a few
lumens (798 vs. 803) to almost 200 (703 vs. 898). Usually when
someone on CPF refers to a "high bin" LED, this is the rating they
are talking about. "C" is the lowest bin I would ever use in a light.
The SWO is the rating for color temperature and tint. The specifics
are more complicated. Talking about a warm, neutral or cool LED
is refering to this.
The "I" is the rating for forward voltage. I and J are the ones
normally used for flashlights. This is basically how efficient the
LED is. An "I" likes a voltage range from 3.25 to 3.50 V, but we
are typically overdriving them for higher output. This is the voltage it
requires to achieve the rated output. A "J" needs 3.50 to 3.75V which is
less efficient though more tolerant of being overdriven at a high current.
I hope this sheds some light on the subject. :cool:
