Re: Info on longbow PR head
Beam shots would be essentially identical to any beamshots of PR, PR-T, Aleph 1 or Pelican PM6 LED beam shots as effectively the same reflector is used by all. The stock micra LED module requires a modified PR or 27 MM reflector as the reflector can not seat down on the LED as far as in the cases of the other PR or 27 MM hosts.
