Omega Man
Well limited to the number of single cell lights, at least.
Always on the lookout for a better headlamp, I knew that I had the means to whip one up myself. And I knew the Inova 24/7's headstrap was the key.
It took me two days of putting it off and not thinking of it, when suddenly it hit me. Flip it upside down! Wear the headstrap upside down, so that a light swings from down-to-up, instead of how the 24/7 faces forward-to-down on the swing arm.
Right now I'm using broccoli rubber bands, since they're plentiful, thick, and small sized.
Here was the first attempt, Fenix L0PSE. I have a River Rock clip on the L0PSE, and actually clipping it to the arm works great, but will stretch the clip out if I left it on there alot.
http://i38.tinypic.com/szwemu.jpg
A shot of the clip on the swing arm:
http://i36.tinypic.com/28tkowg.jpg
A Fenix L1S, it works well as well as a L1P, and any other model I'm sure:
http://i38.tinypic.com/fv1o1.jpg
A Q3 on there, needs two bands to keep it stable. I could use the clip also and just one band for a more stable fit, but again, those clips stretch easily:
http://i37.tinypic.com/2uzz3uu.jpg
http://i38.tinypic.com/2aetb0j.jpg
So it seems any single cell light, a Surefire E1E, E1L, Fenix L1x, AAA lights work great since they're light weight, and even CR123 lights work, when properly secured. Using a light's clip on the arm, the way the 24/7 is supposed to clip to it, works great. I really think this may be The End of headlamp searching for me. With the Q3 on there, it's exactly what I want.
L0PSE comes in at a close second, only because the Q3 is brighter.
This was one of those moments where something so unimpressive and trivial, makes you feel like you just cured the common cold. You shoulda seen how excitedly I ran around lashing lights to this and playing around the dark bedroom.
I hope at least one person gets pleasure and use of this thread. And if it's been done before, I apologize.
