mdocod
UPDATE 8-8-08!
The adapter has been finalized, the sales thread can be found here:
http://www.candlepowerforums.com/vb/showthread.php?p=2585641#post2585641
Any further discussion should be continued there.
Thank You,
Eric
Been messing around with this idea for awhile and decided to do a little cutting and drilling yesterday.... here's a prototype. (updated prototype 5-5-08)
Only problem is.. I'm a pizza deliver driver, which means an M6 isn't something I can justifiably own on my budget, lol...
So... if you are an M6 owner who has 2 working 18650 cells (one of mine is dead, for some reason) who would like to help out by testing this, say so in this thread, first to respond who meets requirements gets it!, reward will be in the form of a free adapter. oh yea...test candidate must live in the U.S. (easier/cheaper communication, faster mailing, etc etc)... All I need the tester to do is see if things fit, see if things line up, and make a few suggestions to improve the design based on actually having an M6 in front of them with the adapter, having a few bulbs available to test the adapter with wouldn't hurt, but the standard MN20 will do fine.
Prototype tester found!, Thanks JetSkiMark!
Here's some of the obvious and maybe less obvious configurations that could be done with this adapter:
2x protected AW/Pila/Wolf-Eyes 18650 LiCo02 cells driving lamps designed for the M3T:
SF MN15 or MN16, or LF HO-M3T or EO-M3T.
2x protected AW/Pila/Wolf-Eyes 18650 LiCo02 cells driving the SF MN20 for extended bulb life compared to M3T bulbs.
2x unprotected quality cells (LG) used responsibly driving a MN21. (this isn't totally safe, experienced Li-Ion users only!)
OR... (not sure if anyone had thought of this yet)
A pair of the 18650 size lithium manganeze oxide cells. Sold by Emoli, and often found in power tools (I have seem the in the new Ryobi Li-Ion kits) driving a MN21.
OR....
A pair of 18650 size Lithium Nano iron Phosphate cells, (A123 systems, found in black and decker VXP system) or alternatively, a pair of lithium iron phosphate cells form online somewhere provided they are rated for high current. This would require purchase of more specialized charger. (~3.6-3.8V peak charging)... I think this could be used to drive a 5761 in a FM MN bi-pin tower.... (provided the bulb fits through the reflector hole?)...
If you are interested in this adapter for your M6 (or COLLECTION of M6s, I know there are a few of you ), let me know in this thread.
Oh forgot to mention, the prototype pictured above is made from 1.25" diameter end caps, the final version would probably be made form 1.375" end caps to come closer to "filling out" the M6 body.
Thank You,
Eric
OR....
