TooManyGizmos
..... I'm wondering since we all use it on our lights - as of recently. (growing popularity)
Lets say .... we use it in the head of our light , on the pos.+ terminal and on the neg.- contact ring. (such as a Nitecore PD-EX/D10) A drop spreads out !
If we get too much on there and create a liquid film on the circuit board between the electronics/pos.+ terminal/and the neg.- contact ring ....... would that film cause enough conductivity between + and - points ..... that it would slowly drain the battery ~ or cause UI function failures ??
I use Deoxit cleaner in tube(not spray) from FenixStore. The cleaner is 30% clean solution. Deoxit GOLD is only 2% clean solution.
I'm wondering ... after using the 30% cleaning solution ........ is there really any need to apply the other Deoxit GOLD with only 2% clean solution ?
What is in the GOLD 2% .... that is not in the cleaner 30% ? When I read the ingredients in the advertising , I don't see any diff. between the two.
Can anyone REALLY tell me why just using the 30% cleaner solution - is not enough ?
And the original question - is it conductive across conacts of PCB ?
Now please supply your knowledge .........
