LightScene
- Joined
- Sep 12, 2003
- Messages
- 939
If you could keep your batteries cool while they charge at 7.5A in an Energizer 15 Minute Charger would there be any other drawbacks?
On the other hand, if you could keep the inside of the cell cool, this may also reduce the damage to the separator.
I think it's a great question, and the only way to find out a true answer would be to run a few tests...
2 separate groups of cells would have to be cycled repeatedly, one group charged in a refrigerated environment, ideally with a fan mounted to blow on the cells, with the other group charged at room temperature. A few dozen cycles, possible more would be required. Before and after capacity and self-discharge and internal resistance measurements would have to be taken for comparison.
This would be an interesting test, wish I had the equipment to perform a valid test of this :)
Eric
I was given a Rc monster truck for my birthday about 7 years ago. It might even be 9 years ago. The battery is a Nimh 3300mah 7.2V pack.
Now firstly we read all the time that you should not charge nimh batteries is series. Well with these packs you don't have the option to charge them seperately.
Secondly, I bought a car charger for it, simply because it was 3 times cheaper and could be used in the field, and of course because it was charging the pack way faster than the AC charger would have. So its also basically a 15-20 minute charger. And I can confirm that these batteries are still like new. I still get the same runtimes with it.
I have since upgraded to Lipo packs. This ''retired'' 6-cell Nimh pack is currently doing duty in a spotlight I've converted to work with a 5-led DX drop-in.
So I don't know if the rate of charge and heat really drastically reduces the lifespan of AA Nimh batteries. It does not seem to do so with Sub-C cells.
The nimh chemistry can withstand a little bit of overcharging But if you overdischarge nimh packs the real damage occurs as the weak cell gets reverse charged. That's what usually kills these, not overcharging, especially if you use a proper smart charger.
