To provide a bit of perspective, the surface intensity around noon in June on a clear day is roughly 120,000 lux (Tucson, Arizona, USA - southwestern desert). This is enough to cause eye damage if you look directly at the light source - i.e., the sun. The Ra Twisty at 100 lumens is generating roughly 375,000 lux at the exit aperture - using the same surface area. Looking into the exist aperture at close range exposes you to roughly 3 time the light as looking directly at the sun.
True if the angular diameter of the light source at that distance from your eyes is 30 arc-minutes, the same as the sun. The source size will determine how concentrated that energy will be on the retina.
I coudl generate a certain lux value using a bunch of fluorescent tubes, or a really intense arc light, the latter would be much more damaging to look directly at.
In the case of the flashlight, there will be basically two relelvant "light sources" -- the image of the die on the reflector (a "large" source) and the die itself (a "small" source). For the sake of my post, Ill assume we're talking about the die alone, and not the reflector (the spill/light from the die is worse.... trust me :sick2
The die will be approximately 30 arc minutes when the light is 17cm from the eye, assuming an apparent die length of 1.5mm. I know that the dome on a Cree XR-E makes the image of the die bigger than it actually is in reality, which is a square millimeter. If
at 17cm distance the
measured lux from the flashlight is 375,000, the light will be effectively like a 3x brighter version of the sun.
A bare LED at that distance, assuming no reflector and a 90 degree beam angle, would produce roughly ~2000 lux. However, there is still another factor to consider -- pupil diameter. In a completely dark room, the pupil could very well allow in 60x as much light as in the case of someone staring at the sun on a bright sunny day. 2000 x 60 =120,000...
Adding a reflectro could certainly increase the lux, but it's also true that the light from the reflector won't be as concentrated when it reaches your retina, so that's why I didn't factor that in.
However, I will say this -- I once built an aspheric mod which I would NEVER want to look at directly. It was uncomfortable to look at
through closed eyelids. Looking at the sun with closed eyelids does not produce nearly the same discomfort. So think about that for a while :sick2:
To the original poster: my suggestion is to use a light with a light diffusion film on it. Then the "light source size" will be much larger, and the light will be much safer (not as throwy, but thats the breaks).
