is my lamp broken help
roopeseta
(pictures at end)
I have a 2x cr123 K2 luxeon lamp called palmblaze. 1 month ago I bought rechargable 3.7v batteries. They worked fine but lately there was a small problem that yesterday came again and wont go away.
This lamp has 3 operation modes, 1 is full power and 2 is half power and third is blinking. The problem is this: Total output of the lamp on full power is now only about 1/10th of what it should be. I have tested this with 2 different fully charged rechargables and with new normal cr123´s. There is a problem somewhere in the lamp and its not as bright as it used to be.
I had this problem for some time 1 week ago and this lamp went sometimes on full power and then it flickered. It was turned on that whole time. Then when I put normal cr 123's and after I let the lamp rest for 5 minutes, it worked normally. I first thought that this is a contact problem and the back screw was loose, and the batteries didnt give good contact. But just a few days ago I was in the forest with my friend and I used this with no problem with rcr123's. I used 4 batteries and there was no problem
My theory is that the DC DC converter is broken somehow because it couldn't handle the higher voltage. I know the lamp itself isnt broken because I taped 2x cr123 and took wires outta them (plus and minus) and I put them directly to the lamp and it flashed very brightly.
I was thiking if I remove the whole circuitry thing from the aluminium case, I could make it so that it bypasses the DCDC thing and goes like normally when I press the on switch.
Someone who knows how these things have usually been made, can you tell from what end should I try to push the circuitry out from the tube? Do you think its glued somehow in some factory?
This lamp still works but its like as bright as a normal 1 piece of 50mw led.... And its not a low battery problem:<< Help someone please if you know.:candle::awman:
lamp:
lamp head removed:
thanks if someone knows
lamp is broken :< i tried to open it and i smashed the led, ok i must buy new one..
Mate,
Just a note for next time. All is not lost.
I can see you had undid the screws that held the star to its heatsink, and I imagine you then tried to prise the star out.
Take a look at the last photo - notice how you are looking down at the LED through a sort of a funnel?
That's called the head. It unscrews; it may be stiff with threadlocker, but it will come off. Take it off, and clear out the broken bits of your old star.
DX has a choice of new stars you can buy.
The thing you did unscrew was called the bezel, it holds the lens and reflector onto the head.
The heatsink itself should also unscrew out of the barrel which is inside threaded at that point. You might need to break the threadlocker gently with pliers.
Did you understand the above? Post again if you're not sure.
thanks i must test this. i didnt read the forums but its good that after 4 months, i finally read it ehehhe.... sorry no pictures here, pictures are somehwere... ill find them when i have time
