yaesumofo
I wonder about this because Mine took a fall from 4.5 foot to a concrete floor. The light landed right on the bezel with enough force to deform the bezel such that the front o-ring was squeezed and cut. It is sort of hard to explain but after the fall there was a bit of o_ring hanging from an area of high compression.
I have lots of lights most are aluminum and have never seen a bezel hit cause the o-ring to squish out before. I believe that either the D10's bezel area is just delicate or the material is weak. Or both I sent an enquiry to 4x7 and got no response.
To be frank I am a bit disappointed. I am pretty sure that the head on this light is no longer water resistant. I am concerned that the material used is either an low grade 7075 Which should still be a strong material or 6061...The thing is that I have lights made from 6061 which appear to be more robust...
Anybody else have a similar experience with a nitecore light landing on it's bezel in a accidental drop or fall?
Please post experience.
Yaesumofo
Yaesumofo
