No, there isn't a chart that includes every 1 AAA light but I will try my best to type some info out.
The L0P is half the brightness of a L0D-CE on high. The L0P is around 24 lumens and the
L0D-CE(
review) is around 46 lumens on high, around 16 lumen on medium, and around 6 lumen on low(thanks to the twice as efficient Cree XR-E P4 LED, it would be 50-60 lumen with a Cree Q5).
The Arc AAA should be a bit smaller and it is built out of better Al.
Also look a the
Liteflux LF2 Cree(
review),
Liteflux LF2 Seoul(
review, 3mm shorter then the Cree version)
Tiablo A1 and
Jetbeam Jet-?(
review),
comparison of Lf2 Cree and L0D-CE. The Liteflux can be the dimmest of the bunch, down to 0.2% of the current on high.
The Arc might be the toughest but it is nowhere close to he brightest. The other light have no problem taking everyday punishment or the occasional hard impact against a wall and trips through the washer but don't expect them to survive a 5000 ft fall or
5 years in a stream.
Bomb proof: Arc AAA
Brightness with good relibility: L0D-CE or Liteflux LF2
