I have some Duracell 2650's that I suspect are self discharging faster than normal. I have had them for a while and have been good batteries.
I have a BC900 and thought I would use the "discharge" mode on a battery after a few weeks of the AA's sitting idle. However I see that the mode will discharge, but then goes to charge mode after that and it does not seem to retain the mA from the discharge cycle once back into the charge cycle. Am I wrong, or is there a better way?
It seems that the batteries, even after 3 weeks idle, when plugged in read about 1.31 V or so. So, I am not sure if by that one is able to tell because I assume that a battery would plateau at around there for quite a while when idle. I am running test cycle to see if their capacity is normal, but I am not sure if this is any indication whether they will hold the charge normally.
Any (good) advice is much appreciated, thanks!
J
J
