is this charger good for my batteries?
FILIPPO
Italy
I was wondering if my charger was is working any good with my batteries.
I tryed to find a review about it but....anything!
I bought it from a soft-air shop.
here you are some pics:
as you can see it has got two leds one green that is always on, and a orange one that is on when batteries are under charging and tuns off when charging is complete.
To keep batteries hot of the charger it also has got a trickle charge at 70mah (the normal charging current is 700mah)
Now what I need to charge: 9X2/3A abttery pack, and two Battery packs with 9 Elites 1700.
so, the final question is: will this charger "CooK" my batteries or just do his work? :whistle:
thanks in advance!
It looks like it would work, but with a caveat. When using a smart charger with -dV termination on a series pack with 9 cells it helps for the pack to be in a balanced state of charge before charging (otherwise individual cells will produce -dV at different times and the charger may have trouble detecting the signal). This could lead to missed termination and overcharge. To balance the pack a timed charge at a low current of about 200 mA for 12-15 hours is good, but this charger doesn't seem to offer that mode.
Therefore, if you have a charger like the C9000 it may be an idea to put each of the cells through a break-in charge before assembling the pack and to repeat the break-in charge every now and then afterwards. Maybe every 20 regular charges or so -- I'm not sure how often is best.
If you are not able to do that, then watch the charger when you first charge a pack and make sure the yellow light turns off at about the right time (after 3 hours or so). Then leave the pack on trickle charge for another 12 hours after the first charge to help it be fully balanced.
thanks for your suggestions!
I have read on LuxLuthor battery pack sale thread that he condition battery pack before sending them out...
when they'll arrive i'll recharge them @ 700mah and then for 12hrs @ 70mah.
I hope this charger won't reduce life of my batteries..:thinking: I'm considering to get a better charger but its hard to find one in italy...
what about Triton?:candle:
hi, I noticed that when "normal" charging is completed and batteries was being on trickle charge for about 1/2hr they are at about 1,44V....does this mean overcharge?:confused:
thanks!
No, not necessarily. It depends on the cell, since different types of NiMH have different voltages.
For instance Eneloops typically go above 1.50 V when charging completes and hot off the charger may read about 1.49 V. If you leave them to rest they will drop to 1.44 V and then remain fairly stable at that voltage, while slowly declining over a period of weeks to go eventually below 1.40 V.
thanks for your reply.
my batteries are Elite 1500 2/3A in a Luxluthor battery pack. I don't want to cook this beautiful battery pack...that's all..
